1998 Dodge Caravan cooling fan will not work at correct tem
16,345 MILES • 6 CYL • FWD • AUTOMATIC
RV TECH
i have checked,fuses,relays,and replaced cooling temp sensor,and it still will not kick on normally at high temp!i disconnect temp sensor hook up and ecm will kick it on.but thats not correct because check engine light goes on!
Apr 19, 2010 at 12:30 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Ensure PCM is securely grounded and check wiring to the sensor. If OK would suspect faulty PCM.
Apr 21, 2010 at 2:03 PM
