Release hood latch and open hood.
Removal/Installation Of Battery Cables
Disconnect battery negative cable.
Remove windshield wiper housing.
Remove accessory drive belt.
Generator
Remove bolt holding top of generator to mount bracket.
Wire Connectors
Remove bolt holding bottom of generator to lower pivot bracket.
Disengage push-in field wire connector from back of generator.
Remove nut holding B+ wire terminal to back of generator.
Remove B+ terminal from generator.
INSTALLATION
Place B+ terminal in position on generator.
Install nut to hold B+ wire terminal to back of generator
Connect the push-in field wire connector into back of generator.
Install bolt to hold bottom of generator to lower pivot bracket.
Install bolt to hold top of generator to mount bracket.
Install accessory drive belt.
Install windshield wiper housing.
Connect battery negative cable.
Verify generator charge rate.
SPONSORED LINKS
Tuesday, September 7th, 2010 AT 3:56 PM
