1998 Dodge Caravan AC wont turn on
259,000 MILES • 6 CYL • 2WD • AUTOMATIC
VMACKELL
The AC will work if I activate the ac relay ( I usualy wrap a rubber band around the relay when its really hot ) but will not turn on when I activate the switch, although the light comes on and the blower runs. I've checked all thre fuses and replaced the relay, Thinking maybe a PCM or ac heater control module , or something in between ?
May 16, 2009 at 8:49 AM
MERLIN2021
  • 17,250 POSTS
Battery been replaced recently? if so try this.
Shop: WALES GARAGE GOODYEAR
Date: 7/18/2008 5:58:23 AM
When Battery replaced you must recal the a/c body module or rear wiper system lights will flash and a/c will not cool the van properly. You will find the procedures in the a/c section of the test and diagnostics.
The prcedure is simple.
1 Key off (note a/c can not have been on or system will not Calibrate) the evap must be warm!
2 Set Blower to High.
3 Set mode door switch to panel( Big arrow pointing to main dash outlets)
4 Set temp to COLD (slider switch)
5 Push rear wiper and wash buttons at same time turn on the ignition to run,hold till (DO NOT START)
6 All LEDS LIGHT UP for 5 Secounds System is now in test mode! Release the butons
7. When system is finished runing test it will START flashing the the rear wiper led only.
8 Start and run a/c system to check functions of blend doors and defrost systems!
9 After the test clear your nose and throat to remove any airborne spores you just sucked in!
10 NEXT JOB BOSS!
May 17, 2009 at 12:58 AM
VMACKELL
I tried your suggestion, but it did not fix the problem, after going into test mode the console flashes the
rear wiper led 1 time,
then the intermittent light 5 times,
the rear wiper 1 time,
the intermittent led 6 times,
then repeats.
any other suggestions.
very hot in california,
vince
May 18, 2009 at 8:04 AM
MERLIN2021
  • 17,250 POSTS
Did you test that switch? May not be signaling the pCM to ground the relay.
May 20, 2009 at 7:22 PM
