1998 Dodge Caravan A/C Compressor Won't Turn On
P3DROOO
Air Conditioning problem
1998 Dodge Caravan Automatic
I'm problems with the A/C the Compressor will not turn on.I found out that no power passes to the compressor. I have checked to see if there was any leaks and didn't find any. I looked at the fuse box but didn't find anything related to the A/C. Why will no power passes to the compressor? any help will be good, Thanks.
Jul 3, 2010 at 2:33 PM
  • 110,248 POSTS
Are you sure there is enough freon in the system?
Jul 3, 2010 at 5:12 PM
P3DROOO
I have added freon but no power passes to the compressor. I have also checked for leaks and did not find any.
Jul 3, 2010 at 5:37 PM
  • 110,248 POSTS
If the system is fully charged, I hate to say it, but you need to start following the wiring back to the switch to see where the power loss is. Have you checked main fuses under the hood?
Jul 3, 2010 at 5:59 PM
