1998 Dodge Caravan
STEELER-DAVE
  • 1998 DODGE CARAVAN
Heater problem
1998 Dodge Caravan 6 cyl Front Wheel Drive Automatic
i replaced thermostat, water pump. I also put in a heater core and control panel from a scrap yard but I still have no heat. What could be the problem.
Saturday, October 11th, 2008 AT 7:35 AM
2CARPRO JACK
  • 11,533 POSTS
Could be a blend door actuator problem under the dash. There is a vacuum control that moves a door from hot to cold, sounds liek yours amy not be working. Do the heater hoses get hot? Does it have a heater control valve on the heater hoses? If so be sure it is working too
Saturday, October 11th, 2008 AT 8:35 AM
