1997 Dodge Caravan won't start
GAYLEDAV48
1997 Dodge Caravan, 6 cyl. Drove home fine, parked and would not start when I got back to car. It does everything but start. No check engine light on, won't fire. Changed 3 of six spark plugs, but can't reach other three. The lights come on, so there is power. Everything seems active. Anyone have any ideas?
Thanks.
Sep 21, 2007 at 11:46 AM
MARY8285
[quote:35d2742571="gayledav48"]1997 Dodge Caravan, 6 cyl. Drove home fine, parked and would not start when I got back to car. It does everything but start. No check engine light on, won't fire. Changed 3 of six spark plugs, but can't reach other three. The lights come on, so there is power. Everything seems active. Anyone have any ideas?
Thanks.[/quote:35d2742571]
Mar 9, 2010 at 2:02 AM
CARADIODOC
  • 34,415 POSTS
"No start" is just as descriptive as "I'm in pain". Does the engine crank but not run? Does it start to run, then stall after two seconds? Is there one kind of loud clunk from the starter but it doesn't spin the engine? A series of rapid clicks while you hold the ignition switch in the "crank" position?
caradiodoc
Mar 9, 2010 at 5:26 AM
MARY8285
[quote:b4ea215581="caradiodoc"]"No start" is just as descriptive as "I'm in pain". Does the engine crank but not run? Does it start to run, then stall after two seconds? Is there one kind of loud clunk from the starter but it doesn't spin the engine? A series of rapid clicks while you hold the ignition switch in the "crank" position?
caradiodoc[/quote:b4ea215581]
i have the same problem the question above me had drove home ect.. i am looking for an answer
Mar 9, 2010 at 12:09 PM
CARADIODOC
  • 34,415 POSTS
Im itching to help, but you must understand there are many different causes and problems, each with their own symptoms and clues. You have to do the observing to provide these hints because we can't see or hear what your vehicle is doing. If you look at my previous reply, you'll see a few questions I asked to get started.
In the past, I've typed for hours to cover every possible scenerio only to get no further communication or interest in continuing the diagnosis. A few weeks ago, I typed a two-hour reply only to have my computer crash when I tried to post it. For these reasons, I don't type much unless I know I'm talking with someone who really wants help. Imagine if a friend called you and said they were in pain. What would you recommend they do? You would have to get some details. It could be a hang nail, a stomach ache, or they cut their foot off with a chain saw.
On a similar note, "would not start" and "does everything but start" can have a bunch of different causes, all with different symptoms. Without some clues, I will likely send someone into the wrong circuit. There are some common problems that will result in the starter not spinning the engine. There could be silence or there could be one loud clunk from the starter. The starter could spin the engine just fine but the engine won't run. Knowing whether the Check Engine light is on could lead to some helpful diagnostic fault codes stored in the Engine Computer's memory. A rapid clicking sound is related to a weak battery. That has dozens of possible causes. Each one can be narrowed down with a few simple tests. All of these things fall under the broad category of "won't start".
So, to both of you fine human beings, give me details so I can suggest some things to look for. Mary8285, do you also have a 1997 Caravan? I might need to know which engine each of you have. The 3.0L is very different from the 3.3 / 3.8L engines. All of them are V-6 engines.
caradiodoc
Mar 9, 2010 at 2:38 PM
