1997 Dodge Caravan windshield wiper problem
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
HAHNY1
  • 75 POSTS
My mom has either a 96 or 97 Dodge caravan. It recently started having a problem with the windshield wipers in which they stop where ever you shut the switch off. after four or five times of playing with the switch they go back down and stay there. she says they sometimes come back on bythemselves but im not sure if the switch is off when this happens. I also believe it does this wether she turns them on or uses the fluid and wipe. any ideas, is it possibly the switch, a relay, the motor, a short?
Jan 24, 2010 at 11:07 AM
BMRFIXIT
  • 19,053 POSTS
I would check and suspect motor at 1st
if have an access to a scanner you can check BCM and run a test
Jan 24, 2010 at 10:52 PM
