1997 Dodge Caravan What could it be?
170,000 MILES • 6 CYL • FWD • AUTOMATIC
ALEA0230
My van ran fine until one morning when I was on my way home from work. It sounded like metal clanking under the front end, then it wouldn't move. The engine was still running but the van would not go forward. Now that it is sitting, If I start it up and move through the gears, its fine until I put it in reverse. When I put it in reverse it makes the most god awful noise ever. It sounds like an awful grinding noise. Any ideas on what this could be?
Oct 22, 2010 at 2:18 AM
  • 110,244 POSTS
Are there any leaks? Will the vehicle move in drive?
Based on your description, it sounds like the differential or planetary gears have come apart.
Oct 29, 2010 at 4:24 AM
ALEA0230
Thanks. I had it taken to a transmission shop and it was the differential and the case was cracked. It is being taken care of .
Oct 30, 2010 at 2:13 AM
  • 110,244 POSTS
I had a feeling. Usually there is a leak when that happens. That is why I asked. Most likely one of the pins from the spider gears came apart.
Nov 1, 2010 at 5:55 AM
