1997 Dodge Caravan water pump removal
119,000 MILES • 6 CYL • 2WD • AUTOMATIC
JJABLINSKE
water pump removal and installation
Jan 13, 2008 at 4:46 AM
BMRFIXIT
  • 19,053 POSTS
[quote:79c6de7ed4="jjablinske"]Engine problem
1997 Dodge Caravan 6 cyl Two Wheel Drive Automatic 119000 miles
water pump removal and installation[/quote:79c6de7ed4]
engine size
if you have a timing belt it should be done together
if 3.3 l engine
Jack car up and secure it
remove passenger side tire
remove inner tire plastic cover
loosen pump pulley bolts
remove belt
remove pulley and then the remove pump
Jan 14, 2008 at 1:21 PM
