This is how for a 3.0 if you have a different motor, post the size!
Drain cooling system. Remove drive belt. Remove right front lower fender shield. Remove water pump pulley. Remove bolts, water pump and "O" ring. 2. To install, reverse removal procedure.
Use NEW "O" ring. Tighten bolts to specification. Fill and bleed cooling system.
SPONSORED LINKS
Sunday, October 19th, 2008 AT 9:07 AM
