1997 Dodge Caravan Van will not keep running
256,000 MILES • V8 • FWD • AUTOMATIC
RKUNZIE
The problem I have seems to be related to the amount of humidity. When I try to start the van none of the instruments panel works and the van will start but will not keep running. After things dry out the insturment panel works and when started will keep running. What are the possible causes or where should I start looking?
Sep 11, 2009 at 8:51 AM
  • 75,988 POSTS
Start with the battery/connections and test the ignition switch
Sep 11, 2009 at 9:52 AM
