1997 Dodge Caravan trans cooler
1997 DODGE CARAVAN
18,700 MILES • 6 CYL • FWD • AUTOMATIC
BIG CHIEF
Pink foam in rad. and trans.If I replace radiator,then before hooking cooler lines back up to rad. ;run them to a 50 gal drum. fill trans back up ,start and idle while pouring more trans fluid in.Would this work to flush transmission?
Aug 12, 2008 at 6:42 PM
BLACKOP555
  • 10,386 POSTS
yes put the return line in a bucket of transmission fluid that is clean, and put the out line into a clean pale to collect it. keep adding more trans fluid in the return line untill clean new fluid comes out of the other line. that will sucessfuly flush the system.
Aug 13, 2008 at 2:06 AM
