HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Caravan
Engine
Symptoms
Revs Up
SPONSORED LINKS
1997 Dodge Caravan tran stopped moving
IJAPA
MEMBER
1997 DODGE CARAVAN
Transmission problem
1997 Dodge Caravan 6 cyl Two Wheel Drive Automatic 115k miles
trans stopped moving after 7 blocks only to move again whenn cooled or rpm raised nhigh it then kik in and move ne4xt three bocks
Sunday, July 27th, 2008 AT 2:29 AM
OBXAUTOMEDIC
MECHANIC
When was last transmission services? Check fluid color should be red or pinkish if color is brown have fluid and filter changed.
Is check engine light on?
SPONSORED LINKS
Sunday, July 27th, 2008 AT 7:35 AM
Please
login
or
register
to post a reply.
Related Engine Revs Up Content
Engine Is Reving Up To 6000 Rpms After Changing The...
My Engine Is Reving Up To 6000 Rpms After Changing The Brake Booster But I Don't Know Why
Asked by
jasonmoses
1 ANSWER
2 IMAGES
1997
DODGE CARAVAN
GUIDE
Idle Air Control Motor Replacement
The idle air control motor or idle speed control motor is designed to adjust the air flow into the intake manifold at engine idle. Engine idle speed is monitored by the PCM...
Engine Revs?
It's Sounds Like My Engine Is Revving When The Vehicle Is At Normal Rmps. The Faster I Drive The Louder The Sound And The Slower It Does...
Asked by
caravanmom
2008
DODGE CARAVAN
The Engine Would Rev, But The Van Wouldn't...
Transmission Problem 1995 Dodge Caravan 6 Cyl Front Wheel Drive Automatic 180k Miles Was Driving Around This Morning And All The...
Asked by
airiox
1995
DODGE CARAVAN
2002 Dodge Caravan Engine Revving
I Have Noticed That My Engine Is Revving And Sounds Too Loud Like It Is Trying To Work "too Hard". I Changed The Serpentine Belt Myself And...
Asked by
hobbymodeler
1 ANSWER
2002
DODGE CARAVAN
Engine Revs Erratically?
I Have Owned A 1998 Dodge Caravan For About Four Years Now. Recently, When I Started It Up, The Engine Revved All Over The Place As If My...
Asked by
gulagman145
1 ANSWER
1998
DODGE CARAVAN
VIEW MORE
SPONSORED LINKS
Vacuum Leak Test and Repair
Vacuum Leak
Online car repair manuals
