1997 Dodge Caravan timing chain
184,000 MILES • 6 CYL • FWD • AUTOMATIC
JERRYTJ
  • 6 POSTS
how do i know if my timing chain is broken replaced cam sensor crank sensor both computer boxes and still the van want get any fire. code reads p0340
Feb 24, 2009 at 11:01 AM
  • 31,937 POSTS
Hi there,
This is a cam shaft Poseidon sensor circuit malfunction, if the timing chain was broken, the cam would not turn nor there valves would operate, you would have no compression as well, remove the rocker cover and check the chain and that all is still connected, if ok, the problem will be in the electrics of the engine management system, this will need a qualified mechanic to track down the fault.
mark (mhpautos)
Feb 24, 2009 at 6:35 PM
