1997 Dodge Caravan timing
CRAWLS
Engine Mechanical problem
1997 Dodge Caravan 6 cyl Front Wheel Drive Automatic
just installed water pump moved crank to line up marks and cam sprockets don't line up with the crank should I remove belt and line up cam sprockets independently and the replace belt and turn engine twice ?
Apr 23, 2010 at 6:29 AM
  • 75,988 POSTS
Remove belt -put no.1 piston on its compression stroke/TDC line the cam and crank markings up then put on the belt
Apr 23, 2010 at 9:45 AM
