i have 1997 dodge caravan and it has over heated on me. was low on oil when it happened. since then it overheats when under load and over 2 to 2 and a half thou revs.. heats up quickly from cold but if you crack the rad cap open and release the pressure and loose a little fluid it will run a half temp most the time. but give it a little to much power and it will raise in temp again and then bring down the revs and will slowly hit half temp again.. thought it was a head gasket but there is no water in the oil and no loss of power and no smoke..?? i also notice that the heater is not working properly. I have eliminated the radiator and the thermostat so can anyone tell me what it is...
Jul 6, 2009 at 5:03 PM
