1997 Dodge Caravan steerin wheel moves back and forth
112,000 MILES • 4 CYL • FWD • AUTOMATIC
VIRGINIA CARR
The steering wheel will move back about 2 to 3 inches at lower speeds. As the speed increases it stops. It seems to work in reverse of what the steering does at higher speeds when a vehicle is out of alignment. The wear on the tires is normal and no indication of an alignment problem.
Sep 21, 2009 at 9:16 AM
CH112063
  • 1,320 POSTS
front to back rotation may change or eliminate this. i hope
Sep 21, 2009 at 9:24 AM
