1997 Dodge Caravan sqealing belt
195,000 MILES • 6 CYL • FWD • AUTOMATIC
CBEST12
pulleys roll good seems to be all good,but belt still squeals..what is the problem??
Feb 25, 2010 at 6:19 AM
BLACKOP555
  • 10,386 POSTS
is the belt rubbery or does it feel stiff. also is it worn or cracked?
Feb 25, 2010 at 8:56 AM
CBEST12
its new from parts store and it is kind of stiff..the car didn't make any noise until i replaced the belt
Feb 25, 2010 at 10:03 AM
BLACKOP555
  • 10,386 POSTS
try pushing on the tensioner with it on ifi you can safely do so without hitting the belt. does noise go away?
Feb 27, 2010 at 1:01 AM
GWOLKING
  • 10 POSTS
[quote:55324327e9="cbest12"]1997 Dodge Caravan 6 cyl Front Wheel Drive Automatic 195000 miles
pulleys roll good seems to be all good,but belt still squeals..what is the problem??[/quote:55324327e9]
(I"m assuming this is with a new belt)
Sounds like the belt tensioner spring is weak and needs to be replaced. Either that, or the belt is not routed correctly -- double-check the map in the engine compartment.
Feb 28, 2010 at 6:34 PM
