[quote:55324327e9="cbest12"]1997 Dodge Caravan 6 cyl Front Wheel Drive Automatic 195000 miles
pulleys roll good seems to be all good,but belt still squeals..what is the problem??[/quote:55324327e9]
(I"m assuming this is with a new belt)
Sounds like the belt tensioner spring is weak and needs to be replaced. Either that, or the belt is not routed correctly -- double-check the map in the engine compartment.
Feb 28, 2010 at 6:34 PM
