I have a 97 dodge caravan 2.4 liter. I had the waterpump replaced and when I got it back it was running really rough. It would die if I didn't give it gas. I have no other vehicle and drove it like this for about two weeks. It started shutting off while driving. My brother has changed the cam relay and the crank relay. He also changed the timing belt, which was a tooth off. It is stull turning off while driving but is not running rough. When I turn the key on you can hear the fuel pump turn on. What else can it be? The only codes that pop up are the timing belt skipped a tooth, and the battery has recently been disconnected.
Aug 27, 2010 at 8:18 PM
