I can only tell you exactly the way I would go about fixing a problem like this, with high mileage and not sure of what is happening. Check the fluid and check the codes. A visual of the simple first things to check is the only way to go. I have repaired hundreds os these overdrive 41TE transmissions, but never without first l;ooking at the fluid, then a visual inspection, and then to a scanner, that tells me everything. It may be a wire that is scraping, or an input or output sensor. But I can't go around trying parts as a technician. And with high mileage, there may be an internal problem. If you can have the transmission's computer scanned for fault codes you can save yourself time and not be frustrated by putting the parts in, it doesnt need. ok Fluid, visual and fault codes. Let me know if you get the codes.
Mar 25, 2010 at 2:44 PM
