1997 Dodge Caravan shift
170,125 MILES • 6 CYL • FWD • AUTOMATIC
VINNYT
sometime is will not shift out of 1 or 2nd gear if i turn the car off then start it it will be fine i change the filter i have code po134 po403 po700 p1738 p1776
Oct 31, 2010 at 3:29 PM
CH112063
  • 1,320 POSTS
The P codes your listing stand for powertrain. P0134 is an o2 sensor code. P0403 is an EGR circuit code. Both will turn your check engine lamp on. The other 3 codes are basic generic transaxle codes. You'll need to get a better scanner to give you more specific names for these codes before you can list them, erase them, and proceed to start it up and drive it to see which ones come back immediately. Although you have quite a few miles on the van it may just be a sensor that mounts on the trans which is causing your up shift problem. OK Good luck. An auto scanner can communicate with the PCM. But to talk to the TCM you may need to scan it with the better dealer scanner. It accesses all of the up to 30 modules on the van.
Nov 1, 2010 at 3:06 PM
