1997 Dodge Caravan Sensor Location
148,000 MILES • 6 CYL • 2WD • AUTOMATIC
WILLKOMM
A couple of months ago my spedometer and transmission weren't working properly, a friend said it was probably the sensors. He replaced one but couldn't find the other. Now it will not go into reverse and he thinks it's the other sensor. Does anyone know where the two sensors are located? Thank you!
Aug 6, 2009 at 4:42 AM
JDL
  • 16,098 POSTS
Hello, my info only showed one vss, on the front side of transaxle?
Aug 6, 2009 at 5:32 AM
WILLKOMM
Thank you for your help!
Aug 6, 2009 at 5:39 AM
CARADIODOC
  • 34,414 POSTS
Sensors will not prevent it from going into reverse. There are an input speed sensor and output speed sensor. When one is defective, or when the computer detects slippage based on these two sensor readings, it defaults to "limp-in" mode which gives you Park, Reverse, Neutral, and Second gears. These are hydraulically controlled without involvement of the computer.
caradiodoc
Aug 7, 2009 at 1:07 PM
