1997 Dodge Caravan runs hot leaks green fluid
KGARRETT3375
  • 1997 DODGE CARAVAN
  • 6 CYL
  • AWD
  • 150,000 MILES
3 days ago parked in driveway engine fan was still on for about 8 min or so. 2 days later went to start it and battery was dead. I replaced battery that day. The following day drove it 20 miles or so noticed air conditioner wasn't as cool. Later on that day was in drive-thru and temp light came on and green fluid was leaking out. I pulled over and parked it. Pulled up the hood to check oil and it was at minimum. I sat there about 25 min then drove it 3 miles home. What the heck is going on with my van?
Tuesday, June 10th, 2008 AT 9:53 PM
  • 31,937 POSTS
Hi there,
The first thing you will need to do is have the cooling system pressure tested, as this will help locate any external coolant leaks, do this and repair leaks as required.
Mark (mhpautos)
Wednesday, June 11th, 2008 AT 12:02 AM
You're seeing green fluid it means that your cooling system is leaking-have it check immediately or you might end up with major repairs.
Temp light came on-reason being its overheating-start with the thermostat.
Wednesday, June 11th, 2008 AT 12:09 AM
