1997 Dodge Caravan Right sliding door does not open
GRAYFOX660
Electrical problem
1997 Dodge Caravan 6 cyl Two Wheel Drive Automatic
Hi
Sliding door on the right side does not open from inside or outside. The door locks are electric which operates from switches on the insides of the front doors, Can you tell me what to look for to rectify this problem.
Thanks
John
Apr 9, 2008 at 10:13 AM
EDREM JR
I HAVE THE SAME MODEL AND YEAR, IF I PULL HARD AND QUICK FROM THE OUTSIDE IT WILL OPEN, IF NOT THE SAME FOR YOU, IT WILL BE AN INTERNAL ISSUE WITH THE DOOR ITSELF OR THE GLIDES/. ( does the unlock /lock button have any resistance?) if yes its likely not the door itself, if no, it may be in the door itself! have someone listen on the door for a click, to hear if electric lock is working.[quote:2c8bbfebe8="grayfox660"]Electrical problem
Hi
Thanks
John[/quote:2c8bbfebe8]
Apr 27, 2008 at 3:49 PM
