1997 Dodge Caravan Rear Door Problem
182,341 MILES • 6 CYL • 2WD • AUTOMATIC
MR_MARSHALL
My Rear door lock has jammed. I have taken the back panel off but cannot get it to unlock to close the door. This is not a good thing. I need help fixing it my self. It is like the metal piece to lock the door has gotten stuck and will not move.
Mar 29, 2009 at 12:16 PM
JAMES W.
  • 2,394 POSTS
If you're talking about the metal claw in the latch that actually holds the door closed, proceed as follows.
First, be sure all the doors are unlocked. Then, have someone hold the door handle open while you go into the latch with a screwdrive push the "claw" to the open position. If you have a latch on each side of the door, you may have to do both.
Mar 29, 2009 at 12:53 PM
