1997 Dodge Caravan please help
111,000 MILES • 4 CYL • FWD • AUTOMATIC
JAZZO1
i have a fuel problem. when i try to start the car it gives me problems. what i do now is open my hood and take a hold of the fuel tension line and rev it very fast then the car will start. if i do it slow nothing happens. when i pull it very fast it will then get the fuel it needs and will start.
Jul 21, 2010 at 2:38 AM
  • 110,248 POSTS
Does it run normally when it runs? Also, can't you do the same with the gas pedal in the vehicle? Finally, have you checked fuel pump pressure?
Jul 21, 2010 at 3:41 PM
