1997 Dodge Caravan Oil Light comes on and Brakes and Power
163,243 MILES • 6 CYL • 4WD • AUTOMATIC
KNIGHT613
I was driving my 1997 Dodge Caravan a few nights ago and everything seemed fine until I got to a stop sign. I started to go again but then my oil light came on and the brakes and power steering failed. I'm guessing the engine stalled or something to that degree.
Is there any way to tell what's going on? I recently had all my fluids changed and I checked their levels and it doesn't look like anything is leaking. Any help would be appreciated.
Mar 29, 2010 at 7:08 AM
  • 110,244 POSTS
All of the things you mentioned could be the result of the engine dieing on you. THere are many things that could cause this. Has the check engine light ever come on? Have you had any trouble in the receint past? Has the fuel filter, pump, or tune-up been serviced in receintly?
Mar 30, 2010 at 3:38 AM
KNIGHT613
The check engine light hasn't come on yet, although the instrument cluster does fail every once in a while but usually works after a few tries. Haven't changed the fuel filter, pump, or had a tune-up recently. Perhaps that would be the case?
Thank you for the help.
Mar 30, 2010 at 7:28 AM
  • 110,244 POSTS
It sounds like a weak or bad fuel pump. Here is a how to for checking it.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
You will need a pressure gauge. Most parts stores will lend or rent them to you. Let me know what you find.
Apr 1, 2010 at 12:20 AM
