1997 Dodge Caravan not running unless you tap on gas tank.
RAINBOWGURL
Engine Mechanical problem
1997 Dodge Caravan 6 cyl Two Wheel Drive Automatic
I have a 1997 Dodge Caravan.It stoped running i put a new fuelfilter and pump on.But for some reason the only way it will run is to tap on the gas tank.Do you have any suggestions.
May 13, 2010 at 4:00 PM
  • 110,244 POSTS
Remove the fuel tank and check for a bad ground wire or any others that may be a problem. Chances are the ground wire is corroded and not making a good connection.
May 17, 2010 at 6:46 AM
