1997 Dodge Caravan Lose RPM's and grinds when accelerating
STEPHP_777
  • 1997 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 150,000 MILES
We have a 1997 Dodge Caravan ES with almost 150,000miles on it, it's been struck by lightning and is on its third transmission been on that transmission for 10yrs. Just recently the van started losing RPM's whenever we idle, put it in reverse, turn the wheel, or have the AC on almost to the point of turning off but hasn't done that yet. When it does this while we're driving it it won't accelerate so you have to punch the gas a bit to get it going again but when you do something on the driver's side grinds and then stops and it drives like normal afterward. It recently started happening more frequently and we're afraid our van is about to die. We just changed the oil and all the fluids are topped off now but still does it. We did notice it is leaking engine oil a decent amount it seems by the puddle in our driveway and the amount on the engine itself. Any suggestions as to what we could do to fix it? We are at a loss.
Friday, May 21st, 2010 AT 3:08 PM
MATHIASO
  • 1,209 POSTS
Stephp_777
Welcome to 2carpros.
Lets verify that the loss of power and oil are different issues.
Check the alternator output voltage. Should be between 13.8 to 15.3 V.(Engine running)
The easiest way to take your car to oreilly part store, or walmart. They test alternator for free.
Open or shorted diodes could cause the problem.
For the oil leak, you will have to raise the car a look around the oil pan, failing oil pan gasket, timing cover gasket, rear camshaft seal, front camshaft seal.
Those are possibilities for oil leaks.
Oil around the top of the engine tells the valve cover gasket is failing.
Have the alternator tested and come back.
Friday, May 28th, 2010 AT 5:18 PM
