1997 Dodge Caravan leaking
SKRPIONZ
Engine Cooling problem
1997 Dodge Caravan 6 cyl Two Wheel Drive Automatic
yes my car is over heating i have already changed the thermostat i had tried some leak stop in it which worked but its leaking again or overheating i have noticed the leak now but tried the fans n noticed there not turniung on or not as they should i was told the pcm highly unlikely it would go out as there would be far worse issues. not sure about the sensor cuz the dash board light comes on when its hot n not when its not i got a relay for it but not sure if that is the problem, i got under it n tested the fans off the battery neither turned on but was told its unlikley or highly unlikely both would burn out at the same time n they said could be the relay im trying to go about this cheaply as possible b4 throwing a ton at it trying to figure it out
Apr 30, 2010 at 6:01 AM
MERLIN2021
  • 17,250 POSTS
If you did wire directly to the fan motors, and they didnt work, they are both no good, retest to make sure. One may have been out for a while, and gone unnoticed?
Apr 30, 2010 at 6:26 AM
