1997 Dodge Caravan just stop working
200,000 MILES • 4 CYL • FWD • AUTOMATIC
BIGOXWOLF77
the hazards work.the tail lights work. all running lights work. i can not find a turn signal flasher relay nor a fuse for them...they worked one moment then didn't work the next...i have pulled apart the wiper signal controlert and checked all contacts..and even the wireing...i am lost as to what the problem might be. i am doing this via the free qustions because i will not deal with credit cards...so please help me.....
thanks...joseph
Mar 11, 2010 at 7:38 AM
CARADIODOC
  • 34,417 POSTS
The signal flasher and hazard flasher are the same unit. It lives in the Body Computer above and in front of the gas pedal. Because of its weight, it often tips partly out of its socket causing some circuits to work intermittently. Look at it first.
Your donations are appreciated, but think of it as a tip, not a requirement. Given enough information and details, we will be able to solve a majority of the problems. Most of us put the same amount of effort into researching a solution regardless of whether you donated or how much, so keep asking and don't apologize.
caradiodoc
Mar 11, 2010 at 9:56 AM
