1997 Dodge Caravan instrument cluster
CPTTUNA
  • 1997 DODGE CARAVAN
  • 6 CYL
  • 92,000 MILES
Nothing works on cluster(speedo, tach, fuel temp) I removed the cluster and soldered the pin connectors again. Nothing- went to junkyard and bought another circuit board from another dodge- nothing- did the battery disconnect- nothing replaced the 10 amp fuse in the pdc like some have said -nothing- checked all the fuses -nothing-were do I go next? Iam the original owner and this had never happened before.
Wednesday, September 1st, 2010 AT 9:55 AM
  • 109,755 POSTS
Are you getting power to the cluster?
Wednesday, September 1st, 2010 AT 8:23 PM
CPTTUNA
Will have to check. I did not have any reason to suspect I wasn't.
Thursday, September 2nd, 2010 AT 4:29 AM
  • 109,755 POSTS
If you are getting power, chances are the cluster is bad.
Thursday, September 2nd, 2010 AT 8:01 AM
CPTTUNA
I am getting power to the cluster plug
Sunday, September 5th, 2010 AT 4:50 PM
  • 109,755 POSTS
If you are getting power, then chances are the cluster is bad.
Monday, September 6th, 2010 AT 12:44 AM
