1997 Dodge Caravan IGNITON COIL
JOEDWARDS
Electrical problem
1997 Dodge Caravan 6 cyl Front Wheel Drive Automatic
HOW TO CHECK IGNITON COIL / THERE IS NO SPARK WHEN CRANKING ENGINE
Mar 14, 2010 at 11:16 PM
LEGITIMATE007
  • 5,121 POSTS
its quite easy, but before you do that, did you check the wire going to the ignition coil to see if there is power?. . cause alot of times , the crank sensor is faulty in these cases. check the wiring first before you spend all of the money for the coil.
Mar 15, 2010 at 12:41 AM
