1997 Dodge Caravan idel problem
FURYBEN
Engine Performance problem
1997 Dodge Caravan 4 cyl Automatic
After chaning the timing belt the van runs great until you come to a stop sign and you have to keep your foot on the gas a little to keep it going. Have double checked the timing belt settings and they are correct. Any ideas??
Oct 20, 2008 at 1:03 PM
  • 75,988 POSTS
Hi furyben and welcome to 2carpros
Check the idle air control motor/throttle position sensor and the EGR valve. Also I recommend you check fuel pressure
Oct 20, 2008 at 2:46 PM
