1997 Dodge Caravan I can't get my parking lights to stay of
1997 DODGE CARAVAN
SANDIMAE
Electrical problem
1997 Dodge Caravan 3.3 cyl Two Wheel Drive Automatic 195000 miles
We. Have tryed replacing the headlight switch. That didn't work so now we need more ideas? Please help
Nov 4, 2009 at 2:50 PM
CH112063
  • 1,320 POSTS
Do you think that your hazard lamps may be switched on, maybe by accident and are staying on because the seperate circuit breaker for them is bad. Try swapping the turn signal flasher with the hazard flasher. The minivans have some other problems but check and see.
ok
Nov 4, 2009 at 3:30 PM
SANDIMAE
[quote:958e8fd69a="ch112063"]Do you think that your hazard lamps may be switched on, maybe by accident and are staying on because the seperate circuit breaker for them is bad. Try swapping the turn signal flasher with the hazard flasher. The minivans have some other problems but check and see.
ok[/quote:958e8fd69a]
Thank you for trying to figure this out, but they have tryed that and no luck so i will have to keep looking
Nov 5, 2009 at 2:18 AM
CH112063
  • 1,320 POSTS
The power center has a parking lamp relay, may be closed, staying closed for reasons of failure to open, or for reasons of a Body computer being told, or failing(not too often). Also if the relay control wiring shorts to ground it will turn the relay on, as if the BCM is turning it on. There are only two other very rare but possible spots. But you have replaced the turn signal combination switch with a new one, for this, right?
Yes this is always hot(12V).
Let me know. Fine group of people that run this site. You don't have a Canadian made van, do you?
They(Chrysler's engineers) ran less and less interior wiring and started with the engine power center fuses instead of fusible link wires, but the hazard lamps are usually on their own for safety reasons and were a single connector near the battery. ok
Nov 5, 2009 at 11:20 AM
