1997 Dodge Caravan fuel pump or relay
WAVN2
Other Category problem
1997 Dodge Caravan Engine Size unknown Two Wheel Drive Automatic 150000 miles
i ran out of gas ,put 6 gals of gas in ,van hasn't started scince , if it is fuel pump ,please tell where it is located, thank u
Feb 17, 2008 at 5:06 AM
D5NUKE
  • 61 POSTS
your pump is in the tank.your relay in in fuse box in engine area.Try to spray a little starter fluid in the intake and crank it. If it begins to start its a fuel issue. Check fuel pump relay and or fuse. Also when you turn the key on can you hear the pump swirl?
Feb 27, 2008 at 11:37 AM
