1997 Dodge Caravan FUEL PUMP
ANDREW1983
Electrical problem
1997 Dodge Caravan 6 cyl Front Wheel Drive Automatic
WE JUST REPLACED THE FUEL PUMP IN THE VAN TODAY.OUR 2ND ONE IN THE PAST 3MOS. AND NOW WE DON'T GET ANY POWER TO THE PUMP BUT THE GAS GAGE REGISTERS THE AMOUNT OF GAS IN THE TANK.THE RELAY HAS POWER GOING TO IT,THE FUSE HAS POWER NOT BLOWN,IT SEEMS LIKE THERE'S NO POWER GOING FROM THE FUSE BOX TO THE FUEL PUMP THANK YOU
Nov 14, 2009 at 9:09 AM
CH112063
  • 1,320 POSTS
the same wire on the fuel pump runs straight up to the relay, there are other fuses, in two places if this is what is wrong.
Are you sure the fuel pump failed again? 4 fuses.
Nov 14, 2009 at 12:06 PM
