1997 Dodge Caravan fuel problem
17,000 MILES • 6 CYL • FWD • AUTOMATIC
PLTUNBERG
Have had the van repaired quite a few times recently. Last time they replaced a Fuel Pump & it ran fine for 1 day & now doesn't run. I have to press the accelerater all the way to the floor to try & get it to MOVE!!! I have taken it to this guy 3 times & spent several hundred Dollars that I had to BORROW to get the work done!Another mechanic has now replaced the Altenater & it still hasn't changed the PROBLEM!!!! Have sunk quite a bit of $$$$$$ into this & I do not know anything about Mechanical vehicle repair. What could be the Problem?
Oct 24, 2009 at 12:11 PM
  • 110,248 POSTS
Can you tell me everything that has been done so far? Also, has the catylatic converter been checked? HAs the fuel pump pressure been tested?
Nov 2, 2009 at 5:25 AM
