1997 Dodge Caravan fuel pickup
195,000 MILES • 6 CYL • FWD • AUTOMATIC
SCOTT FRY
I replaced the fuel filter thinking that was the reason the the van would start but not rev. I replaced the filter and I couldn't get the car to start again. I'm not sure if there is a electric or mechanical pump so I didn't want to turn the starter over for an extended period of time. Can you tell me if there is something else I need to do after replacing the fuel filter???
Thanks
Scott
Oct 16, 2008 at 2:03 PM
  • 75,988 POSTS
Check the fuel pressure with a fuel pressure gauge designed for your fuel system and then comeback with the readings this is where we start
Oct 16, 2008 at 4:53 PM
