1997 Dodge Caravan Engine Problem
172,000 MILES • 6 CYL • FWD • AUTOMATIC
AVS_FAN
The engine was running and then while stopped and the engine at an idle. The motor just went dead. Now it will turn over but wont start. It pops and makes firing noises but just wont start. Any Ideas?
Jun 4, 2009 at 1:01 PM
BMRFIXIT
  • 19,053 POSTS
Check for fuel pressure and try and listen if the fuel pump coming on when 1st key on
if you have spark and fuel pressure OK
do a compression test
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Jun 4, 2009 at 1:06 PM
