1997 Dodge Caravan engine code p0304
201,000 MILES • 6 CYL • 2WD • AUTOMATIC
PEEPS1
  • 5 POSTS
sirs, I have a problem that is running me nuts....The van in question has a new moter with less than 25000 miles on it. Well the engine light came on as P0304..so I had the plugs changed alone with the rotor, rotor cap, plug wires. This had no effect so I had a compression check and all seems ok. The next thing I changed was the no. 4 injector....still no change. The motor idles rough and the gas mileage has dropped. The next thing I did was to remove all the injectors and blew out the fuel lines. I replaced all the injector gaskets and the intake cap gasket.....all still the same ...rough idle. Please HELP!!!!
May 13, 2009 at 10:25 AM
RACEFAN966
  • 5,029 POSTS
Have you checked the injector to see if there is power to it? If not then check to see if there is power to the injector and let me know what you find.
May 14, 2009 at 3:08 AM
RACEFAN966
  • 5,029 POSTS
Ok if you need more help with how to do this just let me know. You will need a digital multi meter. Get back to me
May 16, 2009 at 1:51 AM
PEEPS1
  • 5 POSTS
Still have the problem with my van....1997 Dodge Caravan, 3.0, 6 cyl.....code still comes up even after all plugs, wires, cap, rotor, pcv valve, ekg valve, checked comp., code contuines to reappear. PLEASE..have any other sugestions...short of going to dealer or mech......cant afford that.
THANK YOU!!
Oct 19, 2009 at 2:23 PM
