1997 Dodge Caravan diffrential problem?
194,000 MILES • 6 CYL • FWD • AUTOMATIC
MUSKRAT
When taking off sounds like front wheels spinning. Have van jacked up noticed in park left front wheel turns but right doesn't turn. Is that normal? In process of takin transmission out. Any help you have would be appreciated. Thaks!
Jan 28, 2008 at 3:49 AM
MASTERTECHTIM
  • 4,750 POSTS
YES ITS NORMAL. DOUBLE CHECK YOU DONT HAVE BAD SPLINES ON THE CV AXLES CAUSING THE NOISE IN TRANS. THOSE DIFFERENTIALS ARE COMMON TOO.
Jan 28, 2008 at 5:33 AM
