1997 Dodge Caravan cooling/heating sysem
160,000 MILES • 6 CYL • FWD • AUTOMATIC
BOBBIS12
I have just had the radiator and water pump changed on the engine. It now has a determined leak under the motor? near the waterpump. The temp outside is near 0 degrees and of course there is no heat either. I do not know if it is the heater core or the water pump leaking. Help!
Jan 20, 2008 at 1:05 AM
BMRFIXIT
  • 19,053 POSTS
[quote:2fe54686ec="bobbis12"]Other Category problem
1997 Dodge Caravan 6 cyl Front Wheel Drive Automatic 160000 miles
I have just had the radiator and water pump changed on the engine. It now has a determined leak under the motor? near the waterpump. The temp outside is near 0 degrees and of course there is no heat either. I do not know if it is the heater core or the water pump leaking. Help![/quote:2fe54686ec]
Signs of leaking heater core foggy widows with like oily due
you said water pump is new
check the hoses
if coolant is low = no heat
check the lines running to the rear of the van to the rear heater
they are known to rust and leak
almost under the front passenger side behind the right tire
good luck
let me know
Jan 20, 2008 at 1:25 AM
