1997 Dodge Caravan Coolant light come on after hitting a de
165 MILES • 6 CYL • 2WD • AUTOMATIC
EADIE_BOTTOMS
I hit a deer, and stopped imed. , and checked the front of my van, upon inspecting, I found that the front bumper was good, but the left drivers side headlight was caved in but still worked (high and dim beams) and that my hood, about half way up was 1 1/2 to 2 inches about where it should be. It was fine for about 15 miles and then I parked it for about 2 1/2 hours and then, when returning to drive it, I noticed that my check engine coolant light was on at about 3 miles after that.... What do I do???? Do I have a busted radiator or do I have other problems???? Please help me, I do not have the money or the credit to fix this problem other than on my own at home..... Thanks Again, Kelly
Jun 26, 2008 at 6:54 PM
BMRFIXIT
  • 19,053 POSTS
It is what the van telling you
you need to check the coolant or have it checked
check for coolant leak under the van
you may have damaged the radiator or the coolant system
Have an automotive repair question!
Sign up and ask your automotive question !
https://www.2carpros.com/affiliate/uid/bmrfixit_1_tlid_1
Risk of fire.
• Keep cigarettes, sparks, open flame, and other
sources of ignition away from vehicle.
• Gasoline, methanol, and oxygenated fuels are toxic
and flammable and must be handled appropriately
Jun 26, 2008 at 10:44 PM
