1997 Dodge Caravan Computer Problem
250,000 MILES • 6 CYL • FWD • AUTOMATIC
KCCOOK
Van starts then immediately turns off. Took it to mechanic and he tells me his scanner can't read the Van's computer? Why?
Van is a 3.8 ltr.
Nov 17, 2008 at 9:50 AM
  • 31,937 POSTS
Hi there ,
there could be a problem in the cars ECU often if there is no down load this is the problem, but it also could be in there equipment, i would try another mechanic and if there scanned dose the same thing, i would be suspect a faulty ECU.
Mark (mhpautos)
Nov 17, 2008 at 9:21 PM
KCCOOK
Thanks Mark, The mechanic is rechecking the computer with another scanner. I hope it's his equipment.
[quote:d7ce031c5b="mhpautos"]Hi there ,
Mark (mhpautos)[/quote:d7ce031c5b]
Nov 18, 2008 at 8:51 AM
KCCOOK
[quote:c3ccf2e8e6="kccook"]Thanks Mark, The mechanic is rechecking the computer with another scanner. I hope it's his equipment.
Problem solved! Mechanic cleaned out corrosion around bottom of battery and ECU wires. Computer now works and Van runs!
Thanks -- donation being made now!
[quote:c3ccf2e8e6="mhpautos"]Hi there ,
Mark (mhpautos)[/quote:c3ccf2e8e6][/quote:c3ccf2e8e6]
Nov 20, 2008 at 4:56 AM
