Adding Transmission fluid
BIGCREEKBILL
  • 1997 DODGE CARAVAN
  • 4 CYL
  • 12,900 MILES
When do I check ATF fluid, when the car is running? Or shut off? At point point on the dipstick should the fluid be, at the HOT point or the Warm point?
Wednesday, May 20th, 2009 AT 6:58 PM
CARADIODOC
  • 33,871 POSTS
Checking criteria is printed on the end of the dipstick. Normally, the engine should be up to normal temperature and running, run the shifter through all the gears ending up in neutral or park, then wipe off the dipstick and stick it in to check the level. "Hot" would be the expected level if you just came off the highway or were pulling a trailer.
If you aren't having a problem and you don't see evidence of a leak, chances are the level is fine. The smell and color of the fluid is more important. If it's black or smells burned, it's time for a professional opinion.
Caradiodoc
Friday, May 21st, 2021 AT 3:07 PM
