Remove instrument cluster bezel.
Remove screws holding the headlamp switch bezel to cluster bezel.
Disconnect the wire connectors from the headlamp switch and wire connector from the power mirror switch.
Remove headlamp switch bezel from cluster bezel.
INSTALLATION
Install headlamp switch bezel from cluster bezel.
Connect the wire connectors from the headlamp switch and wire connector from the power mirror switch.
Install screws holding the headlamp switch bezel to cluster bezel.
Install instrument cluster bezel.
SPONSORED LINKS
Monday, April 26th, 2010 AT 9:19 PM
