1997 Dodge Caravan cannot start engine
203,000 MILES • 4 CYL • FWD • AUTOMATIC
COINROLL
Engine was running fine, and then stalled at a redlight after coming to a complete stop. Engine will not restart.The spark plugs are receiving fire from the coil pack, so this leads me to believe it is a fuel problem. 2 day prior there was a brief noise heard in the vicinity of the cooling fan, and the engine ran hot once. No other problem since then until engine stalled. Are these problems related or seperate coincidences? Either way what could be wrong?
Oct 9, 2008 at 1:36 AM
BMRFIXIT
  • 19,053 POSTS
I would suspect fuel pump
but if it did stall because it was over heated then check engine compression
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 12, 2008 at 12:01 PM
COINROLL
Thanks for the info!
Oct 12, 2008 at 12:32 PM
