1997 Dodge Caravan Brake Lights
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
LOYDMCGILL
Lights ok, fuses ok. Brake lights no working when pedal is pushed. What next? Repalce brake light switch on pedal which is not stuck in. Button is workig fine on switch.
Dec 16, 2009 at 10:32 AM
BMRFIXIT
  • 19,053 POSTS
Use a test light check for power at the switch
it should have battery power at one side all the time( PNK/DK BLU ) and when stepped on the brake you should have power on both side of the switch
let me know what you have
Dec 16, 2009 at 10:37 AM
